Turn signal/warning lights...
Old Dec 2, 2018 | 04:08 PM
Egor's Avatar
Default Turn signal/warning lights...
2001 Montero Sport
Help...
My warning lights and turn signals than
have lost their minds....
My warning lights will turn on while I am driving...
they just stay on, not flashing. While this is happening my turn signals do not work.
when I turn off truck the lights will stay on for a few minutes then shut off. Sometimes they come on when truck has been parked for hours. Operating the door locks can make the lights come on and off, sometimes.....any suggestions?
Old Dec 3, 2018 | 09:52 AM
Don't have an "off the top of my head" answer, but I'd start by checking all grounds and connectors under the dash.
Old Dec 3, 2018 | 05:18 PM
Egor's Avatar
Grounds and such seemed fine when checked...Pulled fuse so battery wouldn't drain....lights stay on...(wtf?)...
unplugged warning light switch...lights stay on....
maybe alarm?
Thought behind this is that operating the door locks seems to affect lights...sometimes..
When I park....the lights seem to go on and off with the dome lights...again...sometimes...
Old Dec 4, 2018 | 09:50 PM
if lights stay on when you pulled the fuse, that means there is some other source of power to them. Do the following: pull the "original" fuse, the lights will still be ON. Pull one by one other fuses until you find which circuit "feed" the lights in this conditions.
Old Dec 8, 2018 | 03:34 AM
Egor's Avatar
Problem solved.
alarm also works lights...
unplugged light relay for alarm.
everything works as should except lights don't flash when alarm is set.
Thank you
gotzenjoi
Dec 2, 2007 01:26 AM
gotzenjoi
Dec 1, 2007 11:53 PM
capecodder
Aug 4, 2007 08:32 PM
ricketter
Aug 17, 2006 03:21 PM
dornstar
May 22, 2006 04:58 PM
