Turn Signals?
Old Mar 27, 2007 | 03:58 PM
ap1999monterosport's Avatar
Default Turn Signals?
Okay, I would say about 95% of the time, when I flip the turn signal lever, both turn signals blink. yeah, BOTH! The correct turn signal flashes normally, but the one that I didn't want to turn on flashes a little dimmer. For instance, say I want to make a right turn, I flip the turn signal lever up and the right turn signl flashes normally, but the left one is also flashing, only a little dimmer (both the exterior lightand the little green arrow inside are a little dimmer). The same thing happens when I flip the lever down to turn left, the Left turn signal flashes normally, but the right turn signal is also flashing, albeit a little dimmer. Sometimes they will work normally, but that's only like 5% of the time. It's getting really annoying, what could it be?
Old Mar 28, 2007 | 10:56 AM
jpmontero98's Avatar
Default RE: Turn Signals?
it could be a wiring defect or some moisture damaged the wiring...either way its wiring that is damaged in some way take it to a shop and have them look at the wirng through out the car
Old Mar 29, 2007 | 01:58 PM
off roader's Avatar
This isn't a common problem and I don't have a schematic but maybe it's a flasher relay or your lighting relay?
Unless you have the schematic, it's almost futile to try to find it unless you know where to look for problems. That said, bring it to a decent mechanic or the dealer.
Mac_attack769
Sep 23, 2006 07:52 PM
udg21
May 2, 2006 04:58 PM
fred
Oct 16, 2005 05:17 PM
Britvalencia01
Oct 6, 2005 11:57 PM
odecca25
Jul 13, 2005 01:58 PM
