Valve Lash Adjuster Installation
Hey guys, been lurking for awhile picking up some good info, but I'm having a problem and can't find an answer using the search function.
1990 Montero(base)
3.0 V6
I'm in the middle of replacing the head gaskets and figured that I would go ahead and check the valve lash adjusters for anything out of the ordinary(one was being noisy). Well, I figured that they would all be the same so I didn't make note of which adjuster came from which valve. A couple of the adjusters have a wider band in the middle of them and seem to compress quite a bit more. Any help figuring out where each of these go would be greatly appreciated. I can probably post a pic when I get home if that would be helpful. Also, I've only taken apart the driver side. I'll be more careful on the other side! TIA.
1990 Montero(base)
3.0 V6
simjack
Apr 22, 2008 11:16 AM
Scottrik
Sep 14, 2005 06:52 PM
