Water drain petcock in block
Old Apr 12, 2012 | 08:09 PM
7-UP BILL's Avatar
Default Water drain petcock in block
I've heard that the 3.5L V6 has an antifreeze drain plug/petcock in the block. Does anybody know where it is?
Old Apr 13, 2012 | 10:46 PM
Mr. Z.'s Avatar
The drain plug on the 6g74 mpi on the left bank is next to the engine mount. It is very hard to locate due to the front axle's drive shaft. On the right bank it is by the heat shield (most easily accessed from behind the front wheel). They are small bolts and the one on the right bank is sitting in the block looking like it's all by itself. My FSM doesn't have a diagram of where its located.
Hope this helps.
Old Apr 15, 2012 | 07:44 PM
7-UP BILL's Avatar
Do both need to be removed or will opening one drain the whole block?
Old Apr 15, 2012 | 08:12 PM
Mr. Z.'s Avatar
Each plug drains one side of the block.
You can achieve a complete flush without pulling the block's drain plugs. Drain the coolant from the rad.. (With temp. setting on hot) fill, run, drain... 3-5 times (I use distilled water). Refill with desired percent mix, run vehicle- test mix for concentration and adjust to desired mix.
bingo95b
May 23, 2014 02:05 AM
owensth
Aug 10, 2010 02:43 PM
dvp13
1st Generation
Dec 29, 2008 07:52 PM
dorian7
Jan 22, 2008 06:09 PM
ttenn
Jun 10, 2006 01:45 AM
