water pump
Old Dec 31, 2007 | 05:54 AM
cdugan01's Avatar
Default water pump
if your water pump completely stops working will it break your timing belt or seize up your motor?
Old Dec 31, 2007 | 03:14 PM
Default RE: water pump
Well, the water pump itself wont mess up the timing belt, or sieze the motor. However, no water circulating = more heat. Now that will sieze your motor. DONT drive the car. Also, if your going to change that, change the tensioner, and the timing belt too.
Old Jan 1, 2008 | 11:48 PM
mxmikie's Avatar
if the shaft breaks or the belt jumps ..........yes it will bend most of the valves and could lock the motor up
Old Feb 20, 2008 | 08:02 PM
killerkaw's Avatar
If the water pump freezes, it will burn up the timing belt very quickly(before the engine over heats
). The timing belt turns the pump. If the timing belt breaks if wont harm the valves though as I have broken 3 belts, I should know.
JohnnyK
Jun 2, 2011 01:10 PM
bcolins
Jul 5, 2007 07:35 PM
g9s5t
Aug 21, 2005 10:01 PM
*master
Mar 4, 2005 11:33 PM
Knaackers
Jan 14, 2005 02:54 AM
