What kind of transmission fluid?
Old Feb 7, 2017 | 11:04 PM
  #21
slinky's Avatar
Default when the spf3 is unavailable and you're in a sotua
Is there a regular ATF THAT would be safe if you're a quart or two low, and the mitz special fluid is not available?
Old Apr 24, 2017 | 07:46 PM
  #22
hbmcgill@yahoo.com's Avatar
Originally Posted by Manybrews
I do work for mitsu.
and hes right. Use ONLY mitsu fluid.
Period.
What type of transmission fluid hoes in a 2009 Mitsubishi Galant
Old May 18, 2017 | 11:39 AM
  #23
PalmSprings's Avatar
You can use anything that states sp111. (dont use replacement or compatible) I use hundai sp3 . Search all posts on the subject. They are not all in one thread,so keep looking. I & others have submitted a lot of info on the ones you can use and so has "a member "Joel"...x employee A/T man at mitsu as I recall. Chrysler atf 4 can be used too,but all others have to have in big letters sp111.
Come to think of it,the posts are on the other montero forum,whos name/ escapes me after a year since my last visit and a google didnt bring it up today.
Old May 18, 2017 | 11:46 AM
  #24
Originally Posted by redcentinela
Well, well, well, lets figure this thing out.
I have a 1999Montero sport with a 4G92 engine and a R4A51 tranny, which is an Aisin Warner, not a Mitsu tranny.
What type of fluid should I use, the regular ATF +4 or the SP3 Diamond?
A mitsu A/T mech/Eng posted either. I still chose sp3 over chry atf 4
Old Jul 21, 2017 | 12:14 PM
  #25
jayboi's Avatar
heys guys i have a 2000 mitsubishi galant an im trying to figure out whats the best engine oil an transmission oil to use
Old Jul 23, 2017 | 01:36 PM
  #26
Whatever the manual says for the engine. Those numbers are not just made up. There is a reason why specific weight oils are needed. As as transmission fluid, I'd stick to MTF (Mitsubishi trans fluid) only. Call me paranoid, but that is the one that Mitsu transmissions like
Old Jul 23, 2017 | 05:37 PM
  #27
Originally Posted by Rontopia
I was told by the mitsu dealer in phoenix that I could use hyndi splll in my 97 monty. was that wrong? I dont have a dealer within 150 miles of here.. so.I took it that he knew what he was talking about.
Ive usd it for abt 20K miles and works fine. All my driving is mountain hwy/fwy driving from 500 ft elevation to 3500 ft round trip and 5 dys a week. If there was a problem Id know it by now.
Old Jul 23, 2017 | 07:28 PM
  #28
jayboi's Avatar
ok i have a feeling that my automatic transmission is going bad but i have this wired prob when my car is in the 4th gear an i give it more gas it goes back to 3rd gear then when i relase gas it goes back in 4th an pick up speed... anything on that?
Old Jul 28, 2017 | 09:03 AM
  #29
evan-e-cent's Avatar
I had my torque converter replaced 4 times and the transmission overhauled 3 times because of heavy vibration similar to driving on a rumble strip on the edge of the road. It turned out that it was caused by using the wrong type of oil. Take the advice below and buy genuine Mitsubishi oil.
Old Dec 11, 2020 | 04:59 PM
  #30
Originally Posted by 7-UP BILL
Like I posted before, I have been using Castrol Import Fluid Diamond III spec since 30K miles. Trans shifts perfectly and I have no shudder at all. No leaks whatsoever either. I have 120K on it now and am going to do it again. I do not add a drop of trans fluid between changes.
12.11.2020 Hows that trans doing today? miles?
