Wind noise?
Old Mar 17, 2009 | 10:22 PM
2.211pilot's Avatar
Default Wind noise?
I have a 1997 Montero LS that exhibits a noise at speeds above 60 MPH that resemble heavy rain drops on the windshield. It also sounds a little like a loose tie down would sound on your cargo rack as it pounds against the roof. I have checked all of the obvious things. I don't see any loose parts anywhere. I wonder if the windshield could not be seated or sealed properly? Has anyone else experienced this?
Old Mar 17, 2009 | 10:57 PM
jrmdir's Avatar
This may be oneof the "obvious" things you checked, but I've had my windshield trim pieces fly off three times. Before they left for good they made a sound like you're describing. See if you can pry up the black pastic trim pieces on the left or right sides of your windshield.
Otherwise, I don't have a clue.
Ron
Old Mar 18, 2009 | 09:14 AM
2.211pilot's Avatar
Thanks- I will try that. I do have a small rock chip so this may be a good excuse to take it into a professional and have the chip repaired and the trim inspected.
Old Mar 18, 2009 | 11:51 AM
FAX68's Avatar
Do you have those visor on the door? those make wind sound too
Old Mar 18, 2009 | 11:52 AM
FAX68's Avatar
If you don't have water in your cabin or dash it might not be the sealant.
Old Mar 18, 2009 | 09:36 PM
2.211pilot's Avatar
No I do not have the window or door visor's and I don't have any water damage.
armymen
Jul 21, 2012 10:10 PM
Tasman
Apr 24, 2009 02:43 PM
biscuit
Mar 2, 2008 10:57 PM
Ray00
Dec 27, 2004 04:30 PM
silver outland
May 25, 2004 03:54 AM
