"Foggy" fog lamp?
Old Jan 18, 2009 | 02:55 PM
Zox's Avatar
Zox
Default "Foggy" fog lamp?
Hi to all!
I`d like to ask, have somebody some experience/problem with original "valeo" front fog lights?
I noticed, that my fog lamps got some fog on glass inside, after use in drive. That fog looks like some light-gray smoke... The lights are working... Outside was -5 C`
My outie is 2008, DI-D 2.0 instyle +navi...
Zox.
[IMG]local://upfiles/17746/69AB92A130F84FCD9F399508C4617809.jpg[/IMG]
Old Jan 18, 2009 | 03:54 PM
antlip's Avatar
Default RE: "Foggy" fog lamp?
Looks like the light heated up and with the cold air on the outside caused it to fog up inside. I have never seen that happen before. The closest thing I have seen like that is a head light not being 100% sealed and caused condesation to build up on the inside of the light.
Old Jan 18, 2009 | 11:21 PM
BrodyGuy's Avatar
still have a warranty with this fog light? if so i would put in a claim.
Old Jan 19, 2009 | 11:23 AM
rcpax's Avatar
@Zox: So the European Mitsubishi Outlanders came from the factory with Valeo foglights? Is it a NedCar built Outlander?
Old Jan 19, 2009 | 05:44 PM
Zox's Avatar
Zox
I already put a reclamation for that "foggy" fog light in service, they saw that "fog" and promised me, that they will solve that problem...
I go for the 1st service (at 7500km) next week, and I will see.
At the meantime, the fog lights glasses become clear... miracle! probably because outside temperature rise to +6 C`. But it should not happen anyway...
@rcpax my information is that my outlander come from Japan. It arrives to Serbia in August 2008 and had Valeo foglights.
Zox.
Old Jan 20, 2009 | 02:02 AM
BrodyGuy's Avatar
might be a seal that has a pinch in it or a gasket of some kind. you never know with the disposable quality everything is made of these days.
Old Aug 28, 2012 | 02:42 PM
codetrap's Avatar
If they're the same as mine, then the whole fog light unit pops out of the front of the car in order to replace the bulb (in the manual).. what I'd do if I were you is to take them both out, and throw them both in the oven on a very low temperature and bake them a bit to fully dry them out. Check and clean any seals where the bulbs are, and then reinstall them. That should stop the condensation.
batman47
May 27, 2014 12:15 PM
buck6680
Apr 6, 2009 11:55 AM
ShortyRider
Nov 5, 2007 05:25 PM
dksnj
Nov 13, 2006 01:05 PM
95SLracer
Feb 5, 2006 10:28 PM
