03 Outlander XLS 120k service recommendations?
My girlfriend has an 03 Outlander XLS that was purchased around 100k miles with no idea what has been done to it and I'm hoping I can get some guidance as far as what all needs to be done to it.
I pulled the cover off of the timing belt around 112k and it looked to be fairly new (thank god, I get to keep my tax return!), so that's one major service that I can check off the list for now.
The transmission fluid should be changed soon, and this is where I'm going to need the most help. I've found the Diamond SP III for $8/quart on MAP Performance, but I see that Royal Purple Max ATF is listed as meeting the specs for Diamond SP III. I run the RP ATF in the manual tranny in my Mustang and it works really well, but these Japanese trannies always seem to be much more finicky when it comes to oil (my Subaru is a picky bugger). Is there any problem with running the Royal Purple stuff? I work at CarQuest so I can get a deal on it, and it should hold up to ~50k services just fine. I have no problem running the factory stuff and changing it every 30k, I just want this car to last and not give her any troubles.
Regarding the filter in the transmission: I have Googled the crap out of this car trying to figure out everything I need to do and how to do it, and still can't come up with a good answer about the filter. Some say it's meant to be back-flushed by a shop and doesn't really need to be changed, others say that's a waste of time and you'll end up with used tranny fluid being pumped into the car, and others say that by this point the filter doesn't even need changed. I've studied the diagram of the transmission and come to the conclusion I'd rather pay a shop to deal with it rather than risk messing it up, but if it needs to be done it needs to be done.
Rear differential and transfer case seem time-consuming but nothing to worry about, but I haven't seen anything about how to drain and refill the front differential. Any input here would be very welcome. I intend to run Red Line 75w-90 in the front, TC, and rear diff.
Coolant and brake fluid appear to have been serviced recently, will probably hold off another year on the coolant and 2 years on the brake fluid (it still looks new!)
EDIT: Forgot the Power Steering fluid. From what I've read it takes a specific power steering fluid and not to use anything but the factory power steering fluid. I assume I should just buy 2 or 3 quarts so I can flush the old stuff out, top it off, and keep a little extra. Nothing else will work/is recommended?
Is there anything else to be aware of with this car? I'm trying to cover all the bases, she still owes about $5k on the car and walking/biking to work is not an option. Thanks in advance for any help I can get on this car!
AMSOIL's application guide says the rear diff should use a GL-4 fluid - which seems strange. You should look up the specs on that in your manual to make sure. If RL is a dual GL-4/GL-5 fluid then it won't matter but SVG isn't.
2003 MITSUBISHI OUTLANDER 2.4L 4-cyl Engine Code [G] 4G64 - AMSOIL Online Product Application Guide
The Outlander does take PS fluid instead of ATF if that's what you mean.
I've recently done the PS fluid, transfer case and rear differential on my 2009. The vehicle has been a reliable gas and go vehicle for us.
http://amsoil.nesser.org/tag/mitsubishi/
Is there is a front differential? My 2009 only has the transfer case which I think does double duty in this setup. I put SVG 75W-90 in both diff and transfer case since they both call for GL-5 specs.
mitsubishi « Chris Ness – Amsoil Independent Dealer – Mississauga, Ontario
EDIT: Any ideas on the transmission filter? I can read about it from 3 sources and get 5 different answers as far as what to do about it.
This might help you out - not sure what year its for but it looks like it is for the first generation Outlander which I don't have any experience with. Lots of reading for you!
http://outlander.kiev.ua/manual/Outlander_2.4_AT_MT/
I wouldn't be concerned using a good quality power steering fluid as it is the least stressed fluid in your vehicle. It doesn't see combustion and just needs to control seals and cool as a hydraulic fluid. I don't mess around with additives in any fluid - much rather purchase products that meet the specs provided by the manufacturer.
I have no idea - is there even a pan you can drop to access the filter without having to disassemble the transmission?
Not the same vehicle but this post talks about non-serviceable filters: https://mitsubishiforum.com/forum/mi...109/#post79202
Check out magnefine filters which are often recommended on Bob Is The Oil Guy if you are concerned about filtering the ATF fluid - won't remove the internal one but gives you a serviceable filter.
