05 outlander has issue with starting help !!!
Old Jun 22, 2013 | 02:01 PM
hanns's Avatar
Default 05 outlander has issue with starting help !!!
my family member has 2005 mits. outlander
on and off issue with starting
when try to start the vehicle it will not start can hear engine turning but will not start , when I turn off, I can hear click sound couple times in engine bay and it stops, after 3-4 times it will start the vehicle,
I scan the vehicle and no error code were recorded
dealer told him that ignition is a problem,
we got new ignition switch same thing happens but will not start at all now, engine turns and once turn off the key that click sound is heard and it stops..
I searched but couldn't located answer , there were similar posts few years back but no reply was posted with solution..
Old Jun 22, 2013 | 04:16 PM
Akzle's Avatar
fuel pump, starter throwout. Two that come to mind.
Old Oct 26, 2013 | 12:34 AM
SDP_0820's Avatar
sounds like you are not letting the fuel pump cycle. usually fuel pump runs off battery before you start or during the ignition key turn. I would hazard a guess that the battery is worn and needs replacing. get a battery test done i would bet it is old and fails the test. a newer battery ought to 1. power fuel pump, and 2. turn over vehicle. if the battery is worn you may only be doing the cranking and not getting fuel into the engine.
thoughts anyone?
steve-o
2005 outlander
ralliart engine.
project in planning right now.
montplusrs
Jan 31, 2014 12:45 PM
link
Oct 30, 2012 11:37 PM
ryguy2503
Mar 4, 2012 06:49 PM
Camster45
Jun 13, 2011 09:43 AM
BEAT
Jan 21, 2011 05:42 AM
