07 XLS engine hesitation
Old Nov 23, 2010 | 11:56 PM
cheech's Avatar
Default 07 XLS engine hesitation
Hi, i have a 07 XLS love the car. anywho just wondering if i have a problem or if its normal. I get a slight hesitation from the engine at around 10-20mph in slow but moving traffic. doesn't necessarily have to be in highway it could be in side streets also. when ever i let go of the gas and apply the break or just let go and apply gas again it would hesitate a little. but it goes away as speeds get higher. Is this normal for this car? do any of you outlander owners experience this? should i take it to the dealer? any input would be great.
Old Nov 24, 2010 | 12:29 AM
Alpha-Q's Avatar
I do feel that sometimes but not everyday. Around 1 out of 10 times.
Any input guys?
Old Nov 24, 2010 | 12:56 AM
ivanz's Avatar
Does the engine just give you a bit of power, cut out, and continue or is there just a delay?
Delay is totally normal, and especially if the transmission is in a state where its about to shift (which it usually does when you add gas while moving at slower speeds).
Old Nov 24, 2010 | 11:55 AM
roach's Avatar
Have a look at this TSB to see if it's doing the same thing.
http://outlander.freeforums.org/viewtopic.php?p=152
Old Nov 28, 2010 | 01:14 PM
cheech's Avatar
its definitely a delay. and i tried an experiment too. and when using the paddle shifters and i am manually shifting the delay is almost gone, still there but i guess its normal. thanks for the help.
mari_cf39
Jan 5, 2012 12:26 AM
skateb14
1st Generation
Aug 23, 2010 06:19 PM
member40
Jul 1, 2010 05:03 PM
fcukwithmeprelude
Jul 31, 2007 09:26 AM
jmaxwell007
Jul 12, 2006 03:41 PM
