Misfire, hesitation, and engine dying
Old Jul 29, 2007 | 04:28 PM
fcukwithmeprelude's Avatar
Default Misfire, hesitation, and engine dying
I've got a 98 Eclipse GS with the 420A in it.
All recent service has been done, new spark plugs, wires, coil, air filter, fuel filter, TPS, crank sensor, cam sensor, EGR valve, etc etc. It's timing is perfect (just put on new belt) and everything is exactly as it should. There is no check engine light on.
When at idle (fully warm or cold) it feels like it's missing occasionally. I did a cylinder drop test and all four cylinders are firing. Sometimes after driving for a while when I put the clutch in to come to a stop the engine will cut off. Also, going up some hills that I usually could go up in 5th gear running around 60MPH I now have to drop down to fourth gear to do it. It really feels like I'm lacking a lot of power and I can NOT figure out why!! Any suggestions, PLEASE help me here.
Old Jul 29, 2007 | 04:37 PM
Default RE: Misfire, hesitation, and engine dying
Forgot to mention this is a JDM engine with about 90k on it.
Old Jul 29, 2007 | 04:58 PM
willdue's Avatar
man, i have the same problem, and im always downshifting to actually go. Read my post in this section, see if anything related to you...
Old Jul 31, 2007 | 09:16 AM
willdue's Avatar
bump for you...
Old Jul 31, 2007 | 09:26 AM
RCJr9186's Avatar
what is a JDM 420a?
member40
Jul 1, 2010 05:03 PM
lycan84
Apr 27, 2008 04:02 PM
jmaxwell007
Jul 12, 2006 03:41 PM
1990GSX
1st Generation
46
Nov 10, 2005 11:08 PM
get435
May 22, 2005 03:12 PM
