18 Outlander SE has several dash warning lights, dash + PSteering lose pwr @ random
Old Sep 14, 2023 | 05:21 PM
dustinac33's Avatar
Default 18 Outlander SE has several dash warning lights, dash + PSteering lose pwr @ random
Help! Haven’t saw each of these symptoms at the same time in the other threads. So for the past week my 18 Outlander SE has intermittently threw several dash lights/warnings. ABS, Power Steering, Charging System, Air bag. Etc. when this happens the dash loses power all together at times, and @ its worst even makes the power steering go in and out. After awhile it will stop and act perfectly fine. Other times it’s starts and stops when I engage and disengage the gas pedal. At no point though has the car no crunk right up without hesitation or died at any point during any of this. I’m fact. Outside of the power steering cutting in and out, it’s drives fine all the time regardless of this issue happening or not.
In the past when something like this has happened I would have thought the belt had broken possibly or the battery/alternator or both was bad. The belt is in near flawless condition and has proper tension. I took the car to have the alternator and the battery tested on two occasion and both times it tested in good working condition.
Last thing to note would be that I have been running a volt meter in my 12v receptacle. It always sits around 12.5 in every car I have ever tested. When the car is operating like it should it is pulling between 12.5 and 14 volts. But when it starts having the issues it jumps up to 15-17 volts at that point. Idk if this info helps solve the puzzle or not.
Trying to avoid taking this to the closest Mitsu which happens to be over an hour drive away from me. Thanks for any help you can provide!
Old Sep 29, 2023 | 11:01 PM
dustinac33's Avatar
thanks for all the help community! Good looking out fam.
Old Jan 28, 2025 | 12:50 PM
wayfaerer1's Avatar
@dustinac33
Did you ever figure out what was causing this to happen? Ever get it fixed/resolved?
Having exactly the same problems with my 2017 Outlander and its driving me crazy becuase my local mechanic cant figure out the problem. Battery is fine, alternator is fine, but yet this keeps happening...Something is throwing off the electrical system in the car and because it's impossible to reproduce on demand, it's difficult to figure it out.
Old Mar 15, 2025 | 09:08 PM
Truwarrior22's Avatar
Sounds like an alternator issue over charging..?
triciak
Dec 22, 2015 09:26 PM
JimNAZ
Aug 30, 2014 04:12 PM
Raquel
Jan 28, 2010 04:14 PM
Ricsta
Feb 12, 2005 10:11 AM
Ripley
Dec 19, 2004 04:39 PM
