18 tires
Old Jan 30, 2013 | 01:18 AM
SERPENTOR's Avatar
Arrow 18 tires
What are the largest tires you can install on the 2008 Mitsubishi Outlander XLS 18 Inch wheels without rubbing.?
Old Jan 30, 2013 | 02:20 PM
kizzdog's Avatar
on customizing outlander a guy in nz but 255/55/20s on
Old Jan 30, 2013 | 11:58 PM
gotMDX's Avatar
If u can't find the answer here check tirerack.com. I have used them to search for the right wheel size and decent snow tires. I am pretty sure they can give you recommendations. I have just checked their website about your inquiry but no dice. I'd suggest to call them instead. good luck!
here's a good read..
https://mitsubishiforum.com/forum/mi...-limits-39177/
Old Feb 8, 2013 | 09:18 PM
Elisha's Avatar
245 won't rub but the stock 18" rims are only 7" wide so it's not recommended to go wider than 235 max.
Old Feb 9, 2013 | 12:39 PM
xOutlanderFiendx's Avatar
Old Mar 20, 2014 | 01:21 AM
SERPENTOR's Avatar
Arrow Looking for the best option on 18 inch tires
Is it better to have more Width on the tire or Height? Can others share their different tire sizes on their 2007-2009 Outlanders? Any Rubbing issues?
Old Mar 22, 2014 | 07:14 PM
SERPENTOR's Avatar
Arrow Hmm
Old Mar 23, 2014 | 10:04 AM
boogunoogun's Avatar
Depends on your situation. More width and lower profile tired will give you better traction and handling. The lower the profile the less flex in extreme handling. But the low profile tires have little cushion on bumps let alone pot holes.
Old Apr 12, 2014 | 04:01 AM
SERPENTOR's Avatar
Will this rub 235/55-18?
Old Apr 17, 2014 | 03:39 AM
SERPENTOR's Avatar
What is the biggest tire you can fit on 18" wheels without rubbing?
