2 question from a new owner
Old Apr 2, 2012 | 08:31 AM
shallowz's Avatar
Default 2 question from a new owner
Hello group, just bought a used 2008 mitsubishi outlander xls
I have two questions
1. With the keyless entry when i slide my hand in the handle the driver side door only opens. When reading the manual there is a way to slide my hand in and glide over a sensor or something so I can unlock the passenger side door when I have others driving with me. I have tried sliding my hand in a hundred ways but it only unlocks the drivers side door. How do I do this?
2. When ever i adjust the heat to below 75 degrees the blue snowflake lights up meaning the air condition is on. I always have to press the snowflake to turn it off. How do i fix this so it does not do that?
Old Apr 2, 2012 | 03:52 PM
nesser's Avatar
Welcome to the board!
You configure the car to do one option or the other using your key fob. It is not possible to have both options - only one binary sensor in the handle.
Your owners manual and this post with the utube video should explain how to make the change.
https://mitsubishiforum.com/forum/mi...25/#post278725
This is a feature. Depends on your settings for the other ***** too. But the far left and far right positions (mine is in centigrade, sorry) of your temperature **** are max air conditioning and max heater. I'm sure both of them turn on the compressor for air or defogging.
When you've got the selector on one of the defrost settings or AUTO it will kick on the compressor to attempt and defog the cabin.
I think it turns on the A/C compressor when you've got it set to AUTO and the temperature is turned below the ambient temperature outside - but not sure about that one.
Old Apr 3, 2012 | 11:34 AM
shallowz's Avatar
Thank you
i will watch the video and decide if I only want to unlock the driver side door or them all.
The blue snowflake is annoying but something i guess i have to live with
Thank you
Old Apr 3, 2012 | 03:07 PM
ProcessorHog's Avatar
Shallowz, does your AC kick in on "Auto" temperature setting when the inside temperature is set to lower than air temp? I had this enabled by default in my 2011 Outlander Sport. I disabled the auto-AC activation by pressing and holding down the AC on button for about 10 seconds or so. It may bleep once or twice indicating that the mode has changed.
Not sure if this works on the 2008 big outlander, but thought I'd mention it in case it does.
Zequel
Dec 26, 2014 01:40 AM
IndyEndeavor
Jan 10, 2013 07:01 AM
wolfie8
Jul 20, 2009 07:56 AM
rgsoundguy
Aug 15, 2008 12:00 PM
Macondawg
May 27, 2005 03:27 PM
