20 inch wheels and rubber - Mounted - Pics inside
Yeah you can't get away from the brake dust issue but I find it to be less of an aesthetics issue on these rims- under certain lighting conditions it is not noticeable because of the differing contrasts.
The Outies don't come with pre-drilled holes on the front - its part of the dealer prep. Sounds like the dealer fecked up - I would consider getting them to fix it or you can do as you say and drill them out to make them fit better.
As for the actaul screws - your stealer ought to supply them. If not, go see Napa or Autozone.
is the car abit top heavy? seems upfront to have a big gap more noticeable.. my seem easier to flip over athigher speeds , "not that I drive over the speed limit"..cough".
does any manufacture make aftermarket spring?
Do the 20 inch wheels ride rougher than the stock? i.e. small bumps more noticable on the road. I want to get 20's but I don't want to sacrafice the smooth ride I have now.
They are defintely noisier - given the contact patch is wider than stock; however IMHO it wasn't a Lexus to begin with so WGAS?. But "rougher", I don't think so, in my opinion.
ORIGINAL: rdenis
Now side walls are a completely different matter, and I would agree with you on that. On my previous post I was talking about tire diameter, as a whole, without regards to the side wall height.
