2004 Outlander control arm problem
Old Dec 30, 2019 | 06:39 PM
mirrormirageman's Avatar
Default 2004 Outlander control arm problem
Hello all, long time no see I think. I have a 2004 AWD outlander that had a huge gaping hole (Mama probably hit a rock in the road) on the underside of the drivers side control arm and so it needed to be replaced. Video online showed a nice easy 3 bolt removal. Mine isn't so easy, as usual. I broke the sway bar link, I don't care. I removed the vertical rear bolt surprisingly easy. Front bolt? Eh......I was able to free up the front horizontal bolt about 3/4 of an inch with a ratchet and pipe as an extension and then it just started spinning in place, wobbling the control arm as it spun. I needed easy access to work in there so I cut off my control arm close to that spot and was able to cut the remaining piece out with an angle grinder. I melted the rubber bushing and scraped away all the remnants. I am left with a bolt and sleeve of the bushing as seen in the picture. Bolt turns easily with a wrench. Sleeve spins freely on the bolt. Bolt will not move out OR in. What the heck is holding it in place? I read about a poorly spot welded nut inside the subframe which often breaks free and spins with the bolt in Outlanders and Lancers, but why can't I slide this bolt back IN where it came from if I broke that nut's weld in the subframe. Can anyone enlighten me if the nut is welded inside the subframe at point A or point B or somewhere in between? I tried pulling the bolt out with a crowbar, and I tried hammering it back in. Nope. It spins right in place where it is pictured. I understand that if I broke the nut's weld in the subframe as I was unscrewing it, it would not allow me to remove the bolt any further, but why on earth can I not push it back in freely? That bushing sleeve you see there spins freely. Are there two partitions inside the subframe and perhaps the bolt is on the second one and perhaps I ripped off the bolt with a piece of that partition and now not allowing me back in?
Old Jan 2, 2021 | 08:22 PM
Michael Hearn's Avatar
Yah, my 2006 Outlander control arm front/horizontal bolt just spins and wont come out or tighten. I am quite sure that the hidden/welded nut has become unwelded. Sounds like I may have to cut a hole in the subframe to access the nut . VERY intrusive operation. Does anyone have a better idea other than just trying to
forget about it ?
Old Jul 11, 2021 | 09:46 PM
rbostonca's Avatar
Figured it out yet?
The video makes it look easy (bolts were already loosed up obviously for the video)
Old Oct 22, 2021 | 09:32 PM
gphallus's Avatar
Seems like the best option is cutting the subframe, as much as that's a pain.
Found a fellow who had the same issue on an 03 Lancer and documented his adventure in a 4 part series. Here's the conclusion for you guys:
https://www.youtube.com/watch?v=oJvq...nventionalWAYS
Currently dealing with this on my 06 Outlander, lucky me I already have the new control arm ready so sawing the old one is no biggie. Looks to be the exact same control arm and subframe setup as the Outlander so I'm gonna give this a go tomorrow. I'll take some pics and update post-surgery in case there's any differences, the driver's side nut seems to be poorly welded on a lot of cars from this generation with this CA setup.
MontySport2000
May 2, 2011 03:47 AM
NYMaNiAk
Apr 4, 2007 03:26 PM
Spyder887
Jun 9, 2006 10:59 PM
92_laser
Nov 11, 2005 05:09 PM
