2005 Outlander fault code PO300
Old Aug 21, 2013 | 05:05 PM
gordonsen's Avatar
Default 2005 Outlander fault code PO300
Hello,
I have the orange light coming on frequently with PO300 faulty code. The plugs have been changed but the engine runs still runs rough until it warms up/or changes over to gas. I have had a smoke test, changed the plugs, changed the MAF sensor, the throttle accelerator body and sensor. When warm the engine runs much better on petrol and perfect on gas. When running normally, it picks up as it should and runs without a problem. The coils have been checked (no problem), there are no intake leaks, I'm a bit more than confused, can anyone help please - Gordon
Old Aug 23, 2013 | 06:54 AM
Jeff Collision's Avatar
The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If the problem persist more tests needs to be done to diagnose problem. The other possible causes are: Faulty ignition, Clogged or faulty fuel injector, Intake air leak, Fuel injectors harness is open or shorted or circuit poor electrical connection, Ignition harness is open or shorted or circuit poor electrical connection, Insufficient cylinders compression, Incorrect fuel pressure.
Old Aug 24, 2013 | 09:18 AM
matthewm1965's Avatar
Have you checked the valve clearances?
The gaps close more when the vehicle is run on LPG. The symptoms are more pronounced when the engine is cold - Missfiring, low on power, cutting out.
If you have done more than 50k miles on LPG, then it is worth getting the valve gaps reset.
Matt
Captain_Crusty
Feb 13, 2012 04:25 PM
jay_yrbrgh
Feb 4, 2009 09:18 PM
Larimer522
Jan 31, 2009 07:45 PM
xslim69
Dec 9, 2006 08:49 PM
3000gtyeah
Aug 17, 2005 08:22 PM
