2005 srs airbag light intermittent
Old Aug 15, 2013 | 01:25 PM
beefos's Avatar
Default 2005 srs airbag light intermittent
Hi - in my 2005 2.4L Outlander the SRS Airbag light has started to come on intermittently. On for a few miles then out for a while then back on again.
Are there any known problems with this?
I'm assuming a dodgy connector but where?
Old Aug 24, 2013 | 09:35 AM
matthewm1965's Avatar
From what I have heard, this problem is caused by the ribbon cable that connects to a spiral (clock spring) connector in the steering wheel centre. The cable wears through due to the constant turning of the steering wheel. You will find it gets worse over time, until the srs light is on all the time.
I have the same problem with mine, but haven't fixed it yet due to being nervous about interfearing with the air bag system.
Old Mar 8, 2014 | 05:32 AM
beefos's Avatar
Not attempted this yet but now failed the MOT so I'll have to have a go.
I'm also a bit nervous of the airbag system. I'll remove power before starting work on it - any other tips?
laurenvegan87
Dec 4, 2017 02:48 PM
anothermontero
Sep 17, 2016 12:57 AM
shirell
Jul 22, 2010 03:05 PM
shum_87
Aug 29, 2009 05:05 AM
pgb205
Jun 4, 2009 10:40 PM
