2007 a/c fan max setting problem?
Old Apr 25, 2008 | 08:21 PM
mightyOUTTIE's Avatar
Default 2007 a/c fan max setting problem?
On my outtie, I have a question about my a/c. When I turn the temperature dial all the way to the left (max), every 3-4 seconds or so, I can here the fan in front spinning. It does this constantly when turn to max. Does this happen? My other car don't do that..
When I turn a click up a degree, the fan stop spinning even inthe 3-4 seconds. So basically when the temperature dial is at the lowest temp (max a/c) setting, the fan goes on every 3-4 seconds then stop then goes on again.
Help?
Old Apr 26, 2008 | 01:02 PM
tufduck's Avatar
Default RE: 2007 a/c fan max setting problem?
anyone help him out? I have that problem too.
Old Apr 26, 2008 | 10:14 PM
rtrackr99's Avatar
Yup, mine too.
I don't think that something is wrong...That's probably the designed operation.
One of two fans run on the Max AC setting.
E
Old Apr 27, 2008 | 12:46 AM
DeadPoolinc8's Avatar
it might be the auto function going off ? like if ur car drops in temp it turns the A/C on ? i'm just throwing that out there i havent checked if mine does it
Old Apr 27, 2008 | 12:55 AM
rcpax's Avatar
There is an old thread here in which the issue was discussed in great length.
Old Apr 27, 2008 | 01:37 AM
tufduck's Avatar
been searching but can't find the thread.
So is this a normal problem for all outties?
Old May 5, 2008 | 02:40 PM
n0c7's Avatar
Same deal with my 08, one thing I noticed on the 07's I test drove, thought they would revise it for 08. Nope, very annoying. There is a fix - just turn the stereo up.
No5
Nov 24, 2015 10:18 PM
99clipsgst
Apr 2, 2007 07:55 PM
