2007 Outlander XLS California Radiator Replacement
Old Feb 16, 2024 | 10:52 AM
ibex22's Avatar
Default 2007 Outlander XLS California Radiator Replacement
I currently live in NC and can't pass a vehicle inspection due to a check engine light being cause by a radiator that was replaced. The shop that replaced it thought it would be ok to just zip tie the sensor to the radiator which didn't work. My question is does anyone know of an aftermarket radiator that will work with the sensor? OR is there a way to bypass the sensor? I would have to have to junk the car for something silly like this. Thanks.
Old Mar 4, 2024 | 09:41 PM
KGS's Avatar
KGS
Hi
It will work however the 4 prongs on the sensor which were inserted through the original radiator fins, need to be shorted together before zip tying the sensor back on to the new radiator. Its an anti tamper device and if the pins are not shorted the sensor causes a code to be triggered, I replaced one in Dec 2023 and its been fine since
Old Mar 5, 2024 | 10:31 AM
ibex22's Avatar
Thanks so much for the reply! I was about to junk a perfectly good car since the only option seemed to buy a $1800 dollar radiator which is close to the value of the car.
I'm kinda of new to this so if you could elaborate on what you mean by shorting the sensor? Are you referring to the sensor (DOR I think) that is attached? I know the previous mechanic who installed the new non-CA radiator tried that but probably didn't try shorting it since I still have the check engine light. How do you short the sensor? Thanks again, you are a saint.
Old Sep 10, 2024 | 07:02 PM
Ger's Avatar
Ger
Default 07 Outlander
hello, did you resolve you situation. Can you tell me how.
I having the same issue here.
thanks
Cbuch
Feb 20, 2024 09:00 AM
07xlsguy
Jan 4, 2023 12:10 PM
07xlsguy
Aug 19, 2019 06:58 PM
Derrick Jones
Oct 3, 2018 08:06 AM
Emil
Oct 7, 2015 03:31 PM
