2009 Outie V6 transmission question
Hey all,
Couple of questions..
1. Those that seemed to experience hesitation when applying the gas, does it only happen when in "manual" mode and is it periodic? I have experienced some hesistation and then a pretty hard lurch forward only when in the manumatic mode and this has only happens once or twice a week....
2. Do you notice that it shifts pretty hard into 2nd when in the manu-matic mode? It's really bad upshifting and downshifting when cold, but even when it's warm, it's still a really hard shift. Any other gears, it doesn't do this....
Does anyone experience this? None of these really happen when in automatic mode...
ANy input would be great.
Thanks!
Thanks!
2. Cold shifts are brutal. Toronto has gotten down to a cold snap of -15C this winter while I've owned the outie. It is a huge jolt as the vehicle down shifts into second when coming to a stop while cold - even my girlfriend notices it. I will only to down shift into 3rd, then watch as the car down shifts itself into 2nd while braking to a stop. That is kind of a neat feature, down shift into 5th, then brake normally to a stop and watch the car shift. Obviously the vehicle can't stay in 5th at low speeds.
Once the vehicle warms up it is quite smooth as long as you don't shift from 3rd to 2nd above 3000 RPMS in 3rd. Try to let it fall below until you find the sweet spot for shifting since you can't control the clutch. I don't tend to manually shift up so I can't comment. I hold the right paddle to go into D if I don't come to a complete stop.
I still have my factory fill of fluids. That said I'm not convinced that break in additives or viscosities would cause such hard shifts while cold. I wouldn't expect a flush to change things significantly.
CN
jacarolan
09-20-2011 05:52 PM
Pardy
01-20-2010 11:03 AM
