2010+ F.A.S.T. Key and Remote Start
hi all,
my 10 Outie comes with the F.A.S.T. Key and OEM remote starter, as you see, there are TWO fobs.
then from 2012, Outie Sport star using the new and redesign Key w/remote (below), not sure about if new regular Outies equips this? 12? 13? 14?
my question is can the current two fobs be integrated into the new one? if so, i could simply buy a new fob and ask dealer to program it...and i'll keep the old physical key and the FAST fob for emergency...thanks!
let me put it in this way: I'd like to use the new single fob (the 3rd picture), can the two current fobs be simply substituted with the new one by dealer reprogramming it?
Is it compatible with both FAST and remote 'systems' but without removing or modifying both existing harness inside the car?
boogunoogun: what has to be done to add the function of opening the tailgate/trunk in the third current fob button/pad? Is it possible?
I don't think you can do what you want as the Fast key has very short range and the remote start seems to use a stronger radio signal so you can start the car from further away. From the looks of the original fobs that's what I have arrived at this conclusion.
Wouldn't do you much good. Unless maybe you added really strong pistons, but then shutting it would be a bitch!
auburn4193
03-03-2019 08:27 PM
