2010 Outlander ES: add USB terminal [stock audio]
Old Apr 24, 2011 | 07:28 PM
  #21
armymen's Avatar
Originally Posted by ionicaw
you will get USB on the display if you use steering wheell control button (MODE button)
i just check i dont have the USB on it, but it might be different as i have a 2008, maybe also when they activate the chip, because you need to have your car program to do it, they activate the USB.
i will have to check tomorow if i have that same plug on mine tomorow
keep you inform
Old Apr 24, 2011 | 08:29 PM
  #22
armymen's Avatar
ok i just check mine is not like that at all
Old Apr 25, 2011 | 12:22 AM
  #23
ionicaw's Avatar
Originally Posted by fiestataz
You are right, my 2010 SE has all the BT buttons ready on the steering, but BT was not installed, so my car does not have the USB input ready...
By the way, does anyone here know which Canadian site I can go buy genuine Canadian Accessories/Parts and ships to the States?
Same question for the European Accessories/Parts.
Thanks a lot
if you want a bluetooth module go on e-bay you can get it for $217-325
you can ask seller for more pictures and if it does have USB plug. mine is 2010 made in france, the dealer installed it for me in US (for $535)
I'm not sure if the USB plug is just to program the module to make it work in the car or it can be use to connect I-pod or usb drive. I wasn't able to find the special cable for it.
If somebody else can find it please let me know!
Attached Thumbnails 2010 Outlander ES: add USB terminal [stock audio]-paste-018.jpg   2010 Outlander ES: add USB terminal [stock audio]-capture2.jpg
Old Apr 26, 2011 | 10:04 AM
  #24
madinga's Avatar
This module is made in France while the other was from Mexico.
(still the PN is the same)
Your Outie is european version?
Are the bluetooth modules the same or different in US and Europe?
Needing any changes in HU firmware to attach?
Old Apr 26, 2011 | 07:42 PM
  #25
ivanz's Avatar
The PN number is different. Its a completely different module.
If you get the full FCC ID from ionicaw's picture, you can compare the internals of both on the FCC's site.
Doing a search for cb2mbluec07, yields that Mazda uses the same module.
FCC link for one of them: link
Old Apr 27, 2011 | 06:51 PM
  #26
ionicaw's Avatar
the FFC ID on my bluetooth is CB2MDGMY10
mine is a US 2011 outlander and the dealer ordered the bluetooth and installed for me, but it is made in France
Attached Thumbnails 2010 Outlander ES: add USB terminal [stock audio]-capture3.jpg
Old Apr 27, 2011 | 10:22 PM
  #27
ivanz's Avatar
Link to the new module.
This module looks completely different, higher quality PCB and seems to be more like an embedded computer than the older model.
I can't tell from the photos if its USB or not.
Old Jun 11, 2011 | 06:16 PM
  #28
ivanz's Avatar
Another note: the connector is different as well. I don't see how this module could be used on older Outlanders at all due to different connectors and wiring. The number/colour of wires is completely different.
However, I suppose we would need a service manual from a 2010/2011 Outlander to rule it out completely.
Old Jul 12, 2011 | 09:31 AM
  #29
rutherfordred's Avatar
Originally Posted by ikjadoon
Well, I got a reply from the larger dealership. He told me first that the ES stock audio couldn't take the USB;I asked why and I got this response:
I called Mitsubishi to get some information on this. They were not able to tell me what audio unit you can install that would make it all work together. They said the ES is not equipped to handle the USB cable.
Hmm..so maybe it just doesn't work. Does anyone know how to take the stereo out? Just to see what my options are. Or should I go to the dealer? Hmmm, I'll ask him.
Tell me about it! I drove three hours on the salted highways last night. My car went from Rally Red to Rally Rose. I saw a picture of those headlight washers on a VW GTI; looked cool. I don't know why they can't just offer
the same car worldwide. Probably be cheaper.
I think you need to consult the dealer to take out the stereo or else you can refer the users manual.
pung06513
Aug 7, 2014 02:39 PM
Idz21
Jul 1, 2014 07:42 PM
xOutlanderFiendx
Apr 16, 2013 03:22 PM
mchang40
Apr 25, 2010 10:23 AM
picard
Jan 25, 2010 06:37 PM
