2011 Mistubishi Outlander - No Heat on Idle
Old Jan 15, 2020 | 09:52 AM
armymen's Avatar
Question 2011 Mistubishi Outlander - No Heat on Idle
Good day,
I live in Canada, Alberta. It -53C (127 F), and my issue it that even when I remote start the vehicle for 15 Min, when I get to the vehicle, the oil temperature is still at 0. The only way the vehicle is getting warm it by driving it. Also when I drive it get warm, then when I stop, the heat get very cold.
I know the older 08 model had a TSB for that.
How can I fix this?
Also I live 3h away from any Mitsubishi dealer. Can anybody fix the TSB as per Mitsubishi direction or just the dealer can do it?
Thanks
Old Jan 21, 2020 | 02:04 AM
inuvik's Avatar
Originally Posted by armymen
Good day,
How can I fix this?
Thanks
Are you using a radiator block for these extreme cold temps? You might have low coolant levels that will only push coolant through the heater core while driving because of higher rpms. Check your coolant levels first, if they're ok, cut a piece of cardboard about 1/2 the size of the radiator and place it on the front side (side facing front grille). Try that first
Old Jan 21, 2020 | 05:04 PM
binzd's Avatar
When I lived in a cold area, I always stuck some cardboard in front of the radiator behind the grill to keep that heat in. One possibility is a thermostat stuck open, but that rarely occurs.
sekrettelove14
Dec 3, 2018 07:59 AM
Tacoreia
Jul 5, 2016 12:47 PM
armymen
Sep 23, 2015 10:30 AM
galipec
Jul 4, 2007 02:26 PM
solid102
4th Generation
24
Jan 8, 2006 11:32 PM
