2012 2.2 Outlander 4N14 - Diesel in oil and blue smoke
Old Jan 5, 2026 | 06:21 AM
ndyer82's Avatar
Default 2012 2.2 Outlander 4N14 - Diesel in oil and blue smoke
I have a 2012 outlander 4N14 2.2 diesel. I purchased it with a broken turbo that had sheared off and this has been replaced. I have replaced the EGR and the intercooler, removed and reseated the injectors, and it is blowing out blue smoke.
I initially regenerated the dpf but this did not complete the cycle. it seems the the cycle was still trying to work which may be a reason that the oil filled up with diesel (about 2 litres) over 200 miles.
I did then remove, clean and replace. I told the car it had had a new dpf and took for a run. The regeneration was then showing as off.
I am still getting blue smoke, particularly when I turn right or go around a right hand bend.
Any suggestions gratefully appreciated.
Thanks
simba7
Feb 28, 2025 05:15 AM
hardih
Jan 19, 2024 04:54 PM
nsclews
Sep 18, 2022 05:03 AM
Pauly53
Nov 11, 2021 01:48 PM
PHEVUP
Jan 30, 2016 04:11 AM
