2014 Oulander gt. Cleaned engine now no cold A/C
2014 Outlander gt. Cleaned engine now no cold A/C
I clean the engine out of my 2014 outlander gt with just some light cleaner and then just a spray bottle with water and now the ac will not blow cold air. The little snow flake / AC indicator on the control panel flashed a couple times when I started the car, which I see means clutch slipping. Its now on solid no flashing. I can hear and see the clutch engage, and I can hear inside the car like a pressurizing sound, but no cold air. I checked the pressure switch for water, nothing. I checked the clutch wire, nothing. I checked all the fuses as well. It worked fine before I cleaned the engine. What else could I check?
Fixture
aka Jonathan
Fixture
aka Jonathan
Update. The snowflake / AC icon is still flashing, but the compressor is running. I hear a hissing noise behind the dash when I turn on the air. Some internet research said it could be one of the pressure sensors since everything else appears to be ok.
PalmSprings
08-22-2013 02:53 AM
I Drive Naked
03-14-2007 01:06 PM
