2014 outlander AWD entire front end replace
Old Jul 16, 2021 | 12:22 AM
JTad75's Avatar
Default 2014 outlander AWD entire front end replace
SO my car travels anywhwere it wants across the road sincew the wife hit a curb at 35. My questions are , I am order the rack /pinion , the tie rods inner and outer, and control arms, I need to kno if there is more i need . I mean it is shot. I also ordered strut assembly. can anyone give me advice on any other components i might need. Thank you 911!!!!!
Old Jul 19, 2021 | 10:33 AM
binzd's Avatar
I wrecked the passenger front a couple of years ago, ended up needing lower control arm, tie rod, sway bar link, new wheel and tire, washer tank, fender, headlight, etc.
I bought a pair of struts as I figured it was toast. After disassembling all the wrecked parts, the strut was fine, it hand only been sitting askew, but the way it was mounted allowed it to stay pivoted without damage. I still have the pair of struts for when I need them but didn't end up doing them as none of the spring compressors would work. You need a hydraulic press and blocks to get them out of the springs.
I'd say to take stuff apart before buying. Also a year later the inner cv boot on that side split, probably due to the stress and pulling during the repair (also it was 10 years old, but the other boots are still holding up ok).
Titang9
Aug 17, 2020 12:19 PM
glock116
Jan 4, 2017 11:01 PM
xreturner
Oct 11, 2015 08:14 PM
bs3s
May 5, 2014 11:27 PM
M_O_III
Mar 20, 2014 09:04 AM
