2014 Outlander GT is Fast!!
Old Jun 2, 2014 | 03:43 AM
Krom's Avatar
Default 2014 Outlander GT is Fast!!
Does anyone else own a new outlander GT? Isn't it crazy fast when using the CVT paddles? I wasn't expecting it too be so quick. Im wondering when aftermarket parts will be available for this model. Very impressed with this mitsubishi
Old Jun 2, 2014 | 09:21 AM
ckmecha's Avatar
The GT would have a 6 speed automatic, not a CVT.
Old Jun 2, 2014 | 12:33 PM
Krom's Avatar
Boy the picture would certainly beg to differ...trolling only works when your right guy..
Old Jun 2, 2014 | 12:52 PM
ckmecha's Avatar
CVT - Continuously Variable Transmission. Continuously in the sense that there is no shifting and hence would be no need for pictured shifters....
Old Jun 2, 2014 | 05:57 PM
ahcash's Avatar
funny enough I don't see a lot in Vancouver BC area. I heard they are pretty good..
Old Jun 2, 2014 | 08:26 PM
quadcam's Avatar
Maybe you should look at the specifications and you will see it is as ckmecha says.
Old Jun 2, 2014 | 10:49 PM
2014Outlander's Avatar
Yes, I have a 2014 and it quick particularly at speed. A bit sluggish off the line in my opinion, but then again I'm not out for a race.
As others have stated, it is a 6 speed transmission. Sport-Tronic I believe they call it. The paddle shifters are available for both this transmission and the CVT as on my wife's Outlander Sport.
Old Jun 3, 2014 | 03:06 AM
RoGuE_StreaK's Avatar
Without being argumentative as I'm not sure if you're refering to that one particular model, but my XLS is CVT and it quite definitely has paddle shifters; it forces a pseudo-fixed method if used that way. I only ever use it occasionally for downshifting to keep my speed in check going downhill (which isn't as hard to maintain as a normal auto)
Old Jun 3, 2014 | 11:01 AM
Guyfromhe's Avatar
Paddle shifters on a CVT do seem kind of silly, in 2010 the GT/XLS only came with a 6 speed, the CVT was offered on other trims (with paddles) I guess they changed it in the newer ones because you plain couldn't get a top trim with a CVT before.
Old Jun 3, 2014 | 03:56 PM
Supposedly it kinda works like a clutchless manual, but I haven't had the chance/inclination to really try it. Bit hard for me to get into the manual mindset without the clutch foot action / accelerator release
