2014 Outlander GT - Sudden switch from "D" to 3, 4 or 5
Old Mar 16, 2020 | 04:07 PM
T-time's Avatar
Default 2014 Outlander GT - Sudden switch from "D" to 3, 4 or 5
Driving down the road, car switches to gear other than D, as if I hit the paddle shifter. Is this a basic transmission problem or some other? I would have thought if the transmission were slipping, it still would show as "D" in the selector display, but in my case it switches to a gear number. Happened 3 times on a 15 mile trip. Quite alarming.
Old Mar 16, 2020 | 05:16 PM
albief's Avatar
Does it change gear or just the display change
Old Mar 16, 2020 | 07:40 PM
T-time's Avatar
It changes gear.
Old Mar 17, 2020 | 12:19 PM
AWCAWD's Avatar
I have the following suggestions:
1. Download from this forum the Service manual (the automatic transmission of the V6 model is the same in the 2nd and 3rd generation Outlanders thus, the information is relevant);
2. Follow the procedures underlined in the "A/T DIAGNOSTIC TROUBLESHOOTING STRATEGY" section;
3. It is highly likely that your ECU is throwing diagnostic trouble codes (DTCs). Get a cheap OBD II code reader and read the code(s);
4. Search for the specific DTC in the manual.
5. For the time being disconnect the paddle shifter (the harness is underneath the steering column: see this video at 1:03
or the 5th picture of #906 here. With this you can eliminate or locate the fault of your paddle shifter.
Good luck and report back what you have been able to find.
jsevinsk
Aug 14, 2022 10:36 AM
rsu
Apr 15, 2014 02:27 AM
Donas
Apr 14, 2014 01:20 PM
treasguy
Jan 28, 2010 07:15 PM
