We recently bought a used 2014 Outlander, and when the lights are on, none of the radio or climate controls/buttons light up and are nearly impossible to see in the dark.
Is there a fuse I can check, or something I am missing? The dash lights (odometer, etc) all work fine, and I have checked the dimmer and it is at the highest setting.
None of the fuse labels in the manual seem to jump out at me.
Maybe the light sensor itself is faulty? Another thing to blame is faulty ETACS. Disconnect the battery for 30 minutes and see if it helps after connecting it back.
It is true, the fuse table on the driver-side cover does not tell much....
