2013 Outlander wheels
Old 01-05-2017, 07:57 PM
steeny's Avatar
Post 2013 Outlander wheels
Hi, first time post but long time outlander fan, currently i have a 2013 2wd outlander with 16 inch rims i am looking at "blinging" it up a bit with some new mag wheels but i am having trouble finding anything i like with the recommended size of a 7Jx18 ET38 rim and mainly have been looking at 8 - 8.5 inch rims but have offsets ranging from 33 - 35 was also looking at putting on wider tyres (235/55R18) and was wondering if anyone can recommend a good size rim and offset that would suit without causing any rubbing. Thanks
Old 01-13-2017, 10:01 PM
chris824's Avatar
Default Outlander wheel/tire combination
Hello all:
For 3 1/2 years I had 18" inch OE rims from '13 Outlander 4WD with stock GY LS2 75,923 miles on the tire with regular tire rotation.
Old 01-13-2017, 10:07 PM
chris824's Avatar
Due to weather conditions here in the midwest (we had icy road conditions lately) I had to replace the stock wheels and tires which gives me a better handling. I did have the Discount tire installer test the wheel and tire for any rubbing during install it did turn out good no rubbing at full turning left and right. the steering wheel is much more easier to turn. Please make sure you take the vehicle for wheel alignment at your trusted shop.
Now I have Unique series 42 (part# 42-7712) Black w/Red & Blue Stripes "D" Window 16x7, 5x4.5, 0 offset, 4" rear spacing, 3.3 center bore, approx 33lbs wrapped in 225/70/R16 Cooper AT3 103T SL OWL ITEM: 27147 29 inches, wheels and tires at Discount tire. I choose Cooper over General Grabber due to road noise at highway speeds with only minimal noise at 70MPH. The stock wheel sensors were tranfered to the new steel wheels.
Attached Thumbnails 2013 Outlander wheels-20170112_110534.jpg   2013 Outlander wheels-20170112_110541.jpg   2013 Outlander wheels-20170112_110552.jpg   2013 Outlander wheels-20170112_110607.jpg   2013 Outlander wheels-20170112_114244.jpg
2013 Outlander wheels-20170112_114325.jpg   2013 Outlander wheels-20170112_114334_edit.jpg
Old 01-13-2017, 10:16 PM
chris824's Avatar
here's more photos.
Attached Thumbnails 2013 Outlander wheels-20170112_114230.jpg   2013 Outlander wheels-20170112_114400_edit.jpg   2013 Outlander wheels-20170112_120752.jpg   2013 Outlander wheels-20170112_120800.jpg   2013 Outlander wheels-20170112_120814.jpg
Old 03-17-2018, 10:43 AM
Todoran Mihail's Avatar
Default Wheels unique series 42
[QUOTE=chris824;318840]Due to weather conditions here in the midwest (we had icy road conditions lately) I had to replace the stock wheels and tires which gives me a better handling. I did have the Discount tire installer test the wheel and tire for any rubbing during install it did turn out good no rubbing at full turning left and right. the steering wheel is much more easier to turn. Please make sure you take the vehicle for wheel alignment at your trusted shop.
Now I have Unique series 42 (part# 42-7712) Black w/Red & Blue Stripes "D" Window 16x7, 5x4.5, 0 offset, 4" rear spacing, 3.3 center bore, approx 33lbs wrapped in 225/70/R16 Cooper AT3 103T SL OWL ITEM: 27147 29 inches, wheels and tires at Discount tire. I choose Cooper over General Grabber due to road noise at highway speeds with only minimal noise at 70MPH. The stock wheel sensors were tranfered to the new steel wheels.[/QUO]
Hello, do you still have the Mitsubishi outlander with unique series 42? 😁
if so, do you have a foto with the side of the car or from the side, y like the look but I can see how it's like from the side
thanks!! 🍻
i lunn
08-13-2015 08:31 PM
lancerGTSpenn
02-17-2014 12:02 PM
cmb54521@gmail.com
01-11-2014 10:15 PM
ckmecha
01-08-2013 04:48 PM
catherineapop
12-18-2012 01:07 PM
Quick Reply: 2013 Outlander wheels
