2021 LS 2WD Towing Tandem Jetski Trailer loaded
Old Jan 9, 2023 | 06:18 PM
DADOITZ's Avatar
Default 2021 LS 2WD Towing Tandem Jetski Trailer loaded
Hi Guys,
I have an 2021 LS 2WD outlander and looking to buy and tow an tandem jetski trailer, i know weight wise its ok, unbraked 750kg , brakerd 1600kg, but wanting to know how the 2WD performs on the boat ramp, launching and pulling. I wouldn't be taking it off-road, ie on beach etc as I know it would get stuck.
If anyone has experience in this would be appreciated.
Thanks
Old Feb 9, 2023 | 09:07 AM
homestead367's Avatar
I had a 2013 fwd when I was towing things it felt like the tires would slip on flat/dry ground. My 4wd 2018 does not have that issue. I personally think you might have issues pulling up a boat ramp due to the lack of traction with the weight shifted backwards.
Old Feb 15, 2023 | 08:09 PM
KegRaider's Avatar
I had no issues in 2wd mode on my old ZG whilst retrieving the 13' tinny from the boatramp. Granted, it's probably not as heavy as two jetski's, but if your trailer is balanced correctly it should put not a lot of downforce on the towball anyway. Worst case scenario, if you can't get traction, move your ski's back on the trailer a bit, thus 'lifting' your towball and forcing the car nose down. Obviously, once you are on level ground, crank the ski's back to where they should be.
piper
Feb 15, 2018 01:41 PM
bolts_fan
Jul 3, 2014 03:42 PM
UltraSmooth
May 7, 2012 08:26 AM
Mendigo
Dec 8, 2010 11:18 PM
bender031177
Aug 5, 2010 06:27 PM
