2nd Gen Outlander Accessories((group buy))
Old Mar 15, 2007 | 03:50 PM
  #21
JMC's Avatar
JMC
Default RE: 2nd Gen Outlander Accessories((group buy))
We should get a group buy going for a bigger suit case!
Old Mar 15, 2007 | 08:59 PM
  #22
antlip's Avatar
Were going to have to group buy her a boat to bring all this stuff back.
Old Mar 15, 2007 | 09:31 PM
  #23
JMC's Avatar
JMC
Hahaha....that's even better!
On a side note......I did the old unplug the battery for 45 minutes to reset the ECU trick...and it's probably just me like every other time I do this...but the pick up is so much better!
Here's a lame run down:
Resetting your ECU. Your ECU is your cars brain. It tells your engine what to do and how to do it based on tons of readings it recieves along with how much throttle is being applied and so on.
After you perform any modification to your car. You should reset your ecu so it can clear its memory and re-learn and adapt to the new parts. Instead of having it try to optimize in with its old parts. Its best to reset and let it learn from the new setup....instead of trying to get it to forget the old.
It can be easily done by unplugging the negative battery cable connection. If I remember correctly my chilton manual says 30 seconds. I still try to leave it off as long as possible. Into the night and possibly next morning if you can.
Then you connect the cable back on. Then start the car outside , let it run till its full warm. Normally 5-10minutes during the summer. Some wait till they hear the fan kick on....but you really just need to see the temp gauge at its normal operation position. Do not touch the gas pedal. Then once warmed.
Shut off and use when you are ready.
Also some like to take the car out and run it hard around 3times. Basically 1st through 3rd like you are racing. Of course this sounds kinda weird , I dont know if to believe this. But it cant hurt and it sounds logical , so it doesnt get some weak run and try to learn from that , you immediatly feed it some hard runs to set it self to and you should be good.
You also have to reset it for every mod. I also do it for every season change. This also lets your car adjust to the environment , different humidites and oxygen levels and densities. All are different variables that can effect your cars performance. So to take full advantage , you again want your car to learn and base its settings off a smaller period of time. So resetting it in lets say winter, its like its whole life was driven in the winter , and so on and so forth. Instead of having it try to adapt from its summer time conditions over to the winter...its best to just start fresh.
-- NOTE , do not try resetting your ecu when you have any sort of fuel additives or things in your car that you wouldnt normally have. So fuel cleaners , higher octane fuel , different fuel than you normally run...dont try this then.
Old Mar 16, 2007 | 02:55 PM
  #24
zontarh's Avatar
This is the 1st UK Outi I've seen with any accessories so looks like they can now get it, still no sign of brochure yet tho, this car's a dealership demo (front sports mesh grill, roof bars, mud flaps and luggage carrier)
Old Mar 16, 2007 | 02:57 PM
  #25
JMC's Avatar
JMC
That grill is nice! That might be my first choise.
Old Mar 16, 2007 | 02:58 PM
  #26
zontarh's Avatar
Reds not my 1st choice but I must agree that mesh grill looks damn fine on the red
Old Mar 16, 2007 | 02:59 PM
  #27
JMC's Avatar
JMC
Wonder if it's really bright chrome...it's hard to tell in the pic.
Old Mar 16, 2007 | 03:01 PM
  #28
zontarh's Avatar
Thought you might be able to tell from other angle
Old Mar 16, 2007 | 03:02 PM
  #29
JMC's Avatar
JMC
Yeah....I like it! WOO!
Old Mar 16, 2007 | 03:11 PM
  #30
zontarh's Avatar
For comparison Mesh Grill wins hands down!
If you hadn't already noticed, my Outi photo album is huge
