4wd engaging in 2wd mode when tight turns on loose gravel
Old Sep 4, 2021 | 04:55 PM
jimwise68's Avatar
Default 4wd engaging in 2wd mode when tight turns on loose gravel
Hi all, my 2007 Outie engages the rear wheels when I do a tight turn on loose gravel. Is this correct?
I had this before in a Mk2 CRV and it was the diff fluid. I have changed the diff and gearbox fluid but it still does it.
Is there an issue with my 4wd system or is this normal?
I have checked the data through an iCarsoft OBD reader and the voltages change when using the 2wd/4wd mode selector so that seems to work correctly.
I'm just checking if it is normal for these or mine has an issue.
thanks
Jim
IanA
Oct 10, 2021 03:40 AM
Dsmoovy
Nov 21, 2011 03:00 PM
MooF
Sep 11, 2010 11:12 PM
klas
Apr 3, 2008 01:22 PM
Kwanger
Jan 9, 2008 07:59 PM
