6 month and need changer tire already ????
Old Jun 17, 2008 | 06:20 PM
armymen's Avatar
Default 6 month and need changer tire already ????
i have my outie since end of december, and on the 2 front tire they are very very low, and i think i see the line that tell me its time to change the tire,
i only have 16 k on it normal ?
are that will pass on warantie ?
Old Jun 17, 2008 | 07:46 PM
antlip's Avatar
Default RE: 6 month and need changer tire already ????
Sounds like alot of tire spinning or really hard driving. I have 13k and owned it since new for 1.5 years. Rotated the tires normally and they show basically no wear. I have only spun the tires maybe 1 or 2 times getting use to how it drives and I dont get on it hard or drive it hard.
Old Jun 17, 2008 | 07:55 PM
armymen's Avatar
hi,
with the price of gaz, and with the ACS on i try to now spin tire, the only time i did, was maybe 2-3 time this winter, when i was stock in the snow ( we have a realy big winter and a lot of snow in canada this years )
Old Jun 18, 2008 | 07:00 AM
roach's Avatar
I have nearly 15000 Km on my outie and the tires are still good whit a lot of tread on it. I live in Canada to and let just say that I was happy to have my Winter Tire on for the amount of snow wegot in the Ottawa/Gatineau region I don't know How you managed to run your 4 season all winter.
Old Jun 18, 2008 | 07:33 AM
armymen's Avatar
i was actualy suprise because of the traction control and with the 4wd, this winter for shure i will bought winter tire. But i did not have any problem this winter.
Old Jun 18, 2008 | 01:48 PM
OzarkXLS's Avatar
Greetings
Our Outlander weighs in at nearly 4000 pounds. I use my Outlander daily like no other poster I have read here. I drive 70 miles a day with approx. 195 30-0 mph stops and starts. I have aftermarket wheels and tires on my vehicle and am on my 3rd. yes, 3rd. set of tires. I average about 10,500 miles per set. The vehicle now has 21,600 total miles on it. Just wait, many here will be starting to replace brake pads and rotors. I wore out the factory set (all 4 corners) with just shy of 7000 miles total. I posted a "how to" with pictures on replacing the pads. The front rotors were re-surfaced and aftermarket "Wagner" pads were installed. I have not "heard" from them since and have nearly 37,000 stops and starts on them not counting after hours use. I also can add that I have used the "4WD LOCK" feature 95% of its lifetime and have had no problems or indication of problems. I own an IR temp scanner and have "shot" the diff's on several occasions and not seen any temps above 180º. Considering the outside temps are now in the 80-90º range I find this acceptable. I have noticed an interesting side effect, when the transmission starts to get near critical temps the paddle shifter is locked out and the AC fan starts without the AC running to cool the trans cooler that is a standard equipment feature.
Tires, 2 of my co-workers drive 4WD one a Jeep and one an Escape, they have the same life on tires as I do and possibly less as they are both on set #3 of Goodyear whatever is standard from factory. They both started out new as I did and run less miles and fewer stops per day. They keep asking about my Outlander and how much maintenance I do and I tell them "I am extremely happy I bought this instead of a Ford or Jeep as I have not had 1 dealer visit", unlike them. A tranny issue, a rack and pinion replacement and both have had AC issues. Nearly bullet proof the Outlander is.
Old Jun 18, 2008 | 02:59 PM
06OutlanderSE's Avatar
wow, had my 06 outlander for about 2 years and have 32k and still have not changed the tires, and they look very good still
Old Jun 18, 2008 | 05:09 PM
armymen's Avatar
are the first paire of tire is on waranty ? for less at less a years ?
Old Jun 18, 2008 | 09:20 PM
JohnMadison's Avatar
here is a suggestion, either check your owners manual warranty paperwork or stop out to the dealership. Sometimes things like that are covered for 12k miles or the first 12 months if they are defective. Only a dealer would be able to answer that question. So, just take it in. I've got 28k on my 2006 Outlander and the tires still look good. I'll probably replace them before next winter.
budh
Oct 6, 2023 01:35 PM
blind2go
Jan 17, 2013 08:14 AM
GotBoost
May 24, 2007 09:03 PM
mirageEvo99
Mar 10, 2007 11:42 PM
2007GTEclipse
Sep 23, 2006 08:22 PM
