9 speakers or 7 ???
9 speakers or 7 ???
I have the 650 watts Rockford Fosgate system with 9 speakers, I found only 7 where are the two missing spot. We have one in each door, two tweeters in front and the sub woofer in the back. So where is the spot of the two others. Thank you!
RE: 9 speakers or 7 ???
brian 360 is right. I was just as confused as you were when I could only see 7 speakers. If you do the speaker test in the calibration menu(I think this is navi+set), the rear speakers will play a mid-range tone with intermittent tweeter tones mixed in.
Your rear speaker in the door have a tweeter in them. They should have said 7 in total and called the rear one 2 way speakers instead I think ! At first too I was looking for the 2 missing one when I got my Xls.
