Is the AC working on my 2022 Outlander?
Old Jan 30, 2022 | 09:29 PM
ss98's Avatar
Default Is the AC working on my 2022 Outlander?
Hi All,
Winter here - outside temperature is 55, however the inside feels hot. I set the temp to 65 with A/C on - it blows hot air. If I push it all the way down to 'lo', it feels somewhat cold, but not to the extent I want it to be. In my previous cars, that 'lo' would practically freeze me. How does the A/C work on 22? Does it depend on the outside temperature somehow? Car has only 300 miles (It's an 2022 SE).
Thanks!
Old Jan 31, 2022 | 07:46 PM
eloMeTh's Avatar
Is it on climate control mode (AUTO)? If so it will adjust depending on the ambient temp. If on manual mode it should blow as cold/hot as you set the temp to regardless of the ambient temp.
Old Feb 2, 2022 | 02:52 AM
daem0n's Avatar
Originally Posted by ss98
Hi All,
Thanks!
Most likely it is time to refill refrigerating gas. I hope there is no leak, but any wotkshop have equipment to check leak and refill gas.
Old Feb 25, 2022 | 12:51 PM
NickJagger94's Avatar
Hi All,
Thanks!
Hey I have the same issue. My 2022 outlander has 400 miles on it. It’s cold outside & the air is blowing warm & it’s set on 65, I put it down to low & it blows a lil cool, & no the “Auto” button isn’t on & no it shouldn’t need a recharge since it’s brand new. Me personally I think it’s a faulty auto button that’s just constantly on when the light for it says it’s off.
Old Feb 25, 2022 | 07:56 PM
eloMeTh's Avatar
Might be time to visit the dealer. Probably other owners with the same problems and would help with them issuing TSB (technical service bulletins) or Recalls.
Old Aug 3, 2022 | 01:31 AM
Ps3000gt's Avatar
Hi All,
Thanks!
Did you ever get this resolved? We recently picked up a 2022 outlander and are having issues with the dual climate control. For example driver side side will be cold, while we try to heat up the passenger side side but it remains cold the only way to get a bit of hot air is to put it on high. Seems similar to your issue.
Old Aug 9, 2022 | 08:17 AM
Jantztk's Avatar
Default Update
I had the same issue and I went in. They said there was a massive computer update that they did and flashed the system. It's cold now.
Old Aug 28, 2024 | 06:39 PM
Matt987654321's Avatar
Default Same issue
My ac unit seems to blow slightly cooler air in the passenger side, but far from cool enough for LO setting.
This is the second time I’ve had it back to the dealership for this issue. First visit they said they couldn’t find any leaks and just regassed it. 5000kms later i have exactly the same problem. Considering this is a brand new car, I am shocked to be having so many issues.
Just glad it’s only a company car, otherwise I’d be losing my ****!
newoutlanderfan
Dec 25, 2021 03:16 AM
Goranoslo
Jun 11, 2021 06:55 AM
Nilsc
Jun 7, 2021 03:21 PM
markmarkmark
Jul 25, 2020 12:39 PM
Bethany Trapp
Jun 26, 2017 11:33 AM
