Add OEM Sirius to Base radio? 2011 GT, no upgrades
#21
There's no Rockford Fosgate head unit. They are all same whether with RF or without.
RF on Outlanders consists of 9 speakers attached to 8ch digitally-controlled amplifier.
I've replaced my 2010 6CD radio with 2008 MMCS navi and all RF features are still here.
#22
Wow, I had a 2011 SE and my current 2012 GT both with Sirius. The SE did not have sunroof or RF stereo, the 12 has RF,sun roof and lleather, but not the panoramic roof, just alum. Later I'll get the owners manual out and post the proceedure to go thru to get the Sirius serial/account number from the radio display. If you get the number needed to register/pay, then you have it.
#23
Okay, let's circle back and see if I have this correct.
The CD player is 6 disc, even though it just looks like a standard single disc unit?
It doesn't matter if it is Rockford Fosgate or not. If the Sirius Module is there, it will show up in the Cylon red radio display?
The antenna is soft rubber, therefore it is Sirius capable?
If the Sirius module is not in place, I can simply add one plug'n'play and the correct info will present on the radio display?
#25
To get your Seirius ID no, press a channel seltion button (5 or 6). The sirius ID will be displayed. To stop Sirius Id, press a chanel selection button (5 or 6) and a channel other than 0.
That will tell if the module is there or not.
#27
It gets stranger as we go along. Had a chat with the parts manager at the local dealer. He faxed me the installation instructions and the MUT III diagnostic instructions.
According to what he sent, it is not as simple as just installing the module. Apparently you have to use the diag machine to alter the internal settings in the ETAC section.
Part #MZ360147EX includes the module, screws and the install instructions
Part #MZ360162EX includes the brackets, antenna, antenna cable and instructions.
Any work around for the coding?
#28
It depends on your location. Drive over here, and I can change it for you ![Smile](https://mitsubishiforum.com/forum/images/smilies/smile.gif)
But honestly I don't think it is critical. I'll disable Sirius on mine and will check if it is still available. I'm pretty sure it will be.
