Aftermarket wheels
Old Oct 25, 2015 | 11:16 PM
fiestataz's Avatar
Question Aftermarket wheels
A friend of mine has a set of 20" wheels with winter tires on for sale which I'm really interested in, but it's challenging.
I know at least I need bolt pattern adapters, hub centric rings, new lugs set.....but my question is,
looks like those available matching adapters' (5x114.3 to 5x130) center bore size are all bigger than Outlander's 67.1mm, does that mean I need another set of adapter rings in addition to the centric rings fit on to the new wheels? But I am skeptical that there's such an adapter ring....must the bore size of the bolt pattern adapter be the exact same size as 67.1mm? If so, does that mean I need to order custom made adapter? And how much roughly does such a custom set cost?
Thank you guys
Old Oct 28, 2015 | 05:15 PM
SERPENTOR's Avatar
You are better off getting the correct bolt pattern, by the time you pay for custom adapters and special lugs nuts + the cost of the wheels from your friend. It will be cheaper just doing it the right way. You can get some nice wheels with correct bolt pattern from tirerack.com and Tires & Wheels | Car Tires & Wheels | SUV/Truck Tires & Wheels | Discount Tire
ckmecha
Jan 8, 2013 04:48 PM
roach
Jul 29, 2008 11:01 AM
marcmindte
May 31, 2006 11:08 PM
GonDubs
Apr 26, 2006 09:38 PM
iankz
Apr 15, 2006 01:07 AM
