Air Bags.
Old Apr 10, 2011 | 07:27 AM
milliesdad's Avatar
Default Air Bags.
It's been mentioned to stifen the rear suspension for towing to install air bags.
Anyone know of a distributor for them?
On a similar note, is there a lift support system available for the hood? Really don't like the hood rod thing.
Old Apr 10, 2011 | 07:59 AM
Claude_A's Avatar
callross56's Avatar
I used the Firestone Coilrite 4182 kit and it works great. It doesn't alter the normal ride height but stiffens the rear to stop sagging and it helps handling depending on what pressure you run. I generally run 15psi and 25psi when towing. They took me about an hour to fit and it wasn't hard.
It was someone on this forum that suggested them as well as the gas struts for the hood which work great as well as lifting it higher. I got them from eBay by looking under Outlander parts and I think the brand was sokkie or something like that. reasonably priced and eaisly fitted.
Hope this helps
Old Apr 10, 2011 | 10:09 AM
milliesdad's Avatar
Thanks for the information.
Got the hood lift supports comming- waiting to find out for sure if the 2010 Oultander bags also fit the 2011. They will be next.
Old Apr 10, 2011 | 02:15 PM
Claude_A's Avatar
There is no difference between 2010 and 2011 in the suspension.
Old Sep 10, 2012 | 07:06 PM
harakiriboy's Avatar
I know im late with this but just wanna share this one. I hope this would help, if you are still finding or might want a lift support system my friend suggested it to me and i just want to share it because i just recently bought a lift support here. And i think they have it here. Check Here: Strong Arm Replacement Lift Supports
Old Feb 2, 2015 | 07:19 AM
billb1's Avatar
Do these air spring kits last long?Some say they get puncture holes in them.
Old Feb 3, 2015 | 05:56 AM
2001Mitch3.5XS's Avatar
Depends on the driver really bud... If your careful and are just using them for towing then no problem but if you go 4 wheeling you might not want to use them. They are quite durable though. Very thick plastic. Put them in the sun or bucket of hot water before install.
Old Apr 11, 2015 | 09:15 AM
d420mac's Avatar
Default airbags
does anyone know what air bags/ helper springs are recommended for the 2014? are they the same s the 2010?
jkmd6c
Mar 18, 2008 10:02 PM
5star
Aug 16, 2007 06:03 PM
GST WNB
May 26, 2005 06:10 PM
mitsusandy
Apr 13, 2005 05:28 AM
