Air Conditioning Advice needed
Hi everyone,
I know this is probably a newb question but ill ask anyway.
my air conditioning on my 2010 GT suddenly stopped blowing air through the vents yesty.
I can hear the compressor cut in and out but no air flows through the vents at all.
would it need re-gassing or is it a more serious issue?
would this issue be covered under warranty?
anyone else have a similar problem or advice?
Sounds like you have an issue with the blower. Which is located behind the lower glove box. Possibly as simple as a blown fuse.
What happens when you crank the heat?
Download the service manual on this site. It will help you find the issue.
Or you might still be under warranty and just make it your dealers problem
