Air filter problem
Air filter problem (solved)
Hey all,
got my tires swapped to summer for free at a local shop, but unkown to me, they checked a whole bunch of things, including my air filter.
So I get home and just wanted to make sure everything looked ok, and of course the air filter was visible!!!
This is a brand new vehicle for me (within a few months) and never had tried to open or change my air filter. It looks like it isn't lining up right? This might be a stupid question but which way does the filter go in? Is there a way I can tell if it is reversed?
Also, the manual says if it is opened too far, then the hinges at the bottom come apart. Is there a trick to snapping them back in since I can't see it due to the position of them...
Thanks alot...I don't want to drive the outie without the proper air filter setup...
Any advice is appreciated.
There is only really one way the air filter goes. If its the wrong way, you can't close it, and clips wont attach.
Look for the side with dirt (at lease some), that side faces out, meaning air comes into the dirty side, and then comes out clean, which is the other side into intake.
So if it closes, and clips are attached, you're good!
Yeah, I hear that - I struggled trying to get those locked in...I think it is finally ok....Just makes me laugh that the shop I took it to actually thought what they did was good enough that I wouldn't notice - I mean I actually saw the white of the filter when I looked under the hood - LOL
Thanks all....
gsr94trycatchit
12-19-2004 07:27 AM
