Airtrek/Outlander Brembo Brakes
Old Nov 30, 2012 | 02:35 AM
Gen-8's Avatar
Default Airtrek/Outlander Brembo Brakes
Hey guys forgive me if I am blind, I have someone wanting to achieve the ever threaded evolander build and wants me to do the work .
Iv spent hours on ASA looking at applicable models and bits etc but I cannot seem to find my answer..
What is the Turbo model Outlander/Airtrek's front brake caliper bolt hole centres please and the rears.
Or if anyone knows can I simply bolt brembo s on? Are they nt based on the Evo7 platform?
Old Dec 1, 2012 | 11:34 PM
boogunoogun's Avatar
I would love to know this info as well. Especially if it is bolt on extra stopping power
Old Dec 14, 2012 | 03:51 PM
efthimis's Avatar
i have just installed a set of front 4-pot Brembo brakes from an Evo VII. to fit them you need to change the front knuckles and drives shafts (because Evo's are larger in diameter).
Usin the Evo knuckles the caliper is bolt-on directly and without adaptors (which I didn't want for the front brakes).
Stopping power has dramatically improved.
My intention is to fit the rears as well (using an adaptor), however I would appreciate anyones iinput on how he did.
Old Dec 14, 2012 | 03:57 PM
efthimis's Avatar
forgot to mention that brakes will NOT fit inside the stock 17in wheels. Need to either fit the 17in from the Evo VII, VIII, IX or the 18in from the Evo X. I went for the later, with 235/50 R18.
Old Dec 14, 2012 | 07:24 PM
Burtonrider10022's Avatar
Pics? This sounds great!
Old Dec 29, 2012 | 01:20 AM
Gen-8's Avatar
Indeed sounds great.. I though I'd need to use the driveshafts,but did you use the entire shaft or simply only the outer cv with the knuckle spline on it?
I knew that the brembo won't clear stock rims , we now have HUzge 20" on it now
Old Jan 19, 2013 | 03:42 PM
BrunoBoy650's Avatar
Bump, need info
Old Mar 20, 2014 | 12:16 PM
fiestataz's Avatar
bump! any updates?
Old Jul 27, 2025 | 05:20 AM
modassirbd's Avatar
BrunoBoy650
Oct 8, 2017 09:53 PM
msport_2_outlander
Jan 9, 2015 07:30 AM
ultrarevvin1
Jan 31, 2014 10:44 AM
sirjluc
1st Generation
13
Mar 5, 2011 02:51 AM
TX97GST
May 16, 2006 10:48 AM
