AutoStick problem
Old Apr 3, 2014 | 03:47 PM
genopower@hotmail.com's Avatar
Default AutoStick problem
I have a 2003 Outlander XLS.
The transmission is working fine but if I flip it over for Auto Shift it just doesn't respond. A number used light up on the dash and you could shift up and down. Now it just works like it's in normal mode. Is there a module or something that needs testing?
Thanks
Chuck
Old Apr 3, 2014 | 05:34 PM
You do realize that by creating a username containing your email address, that you're going to get spammed beyond belief, right?
Is there a reason why you need to manually shift an automatic transmission? Or do you just like to pretend like you're driving a manual?
Old Apr 3, 2014 | 06:12 PM
Vadimus's Avatar
Thanks
Chuck
Damaged harness in shift lever switch. Somewhat common issue for 1st gen Outlanders - a bit too short wire breaks due to tension.
Old Apr 4, 2014 | 11:07 AM
Thanks much. I only use it to downshift in the winter and on hills. Anyone know how hard it it to get to/fix?
Yeah, find the broken wire, and re-run it.
It's easy if you know what you're doing, not easy if you don't.
Sephiroth
15
Aug 13, 2005 04:16 PM
