AUX connector?
Hello, I have 2007 Mitsubishi Outlander with 6-CD changer and Rockford audio system+BT... I was wondering where I can buy RCA adapter(online-because local service doesn't have one,and I couldn't find on ebay either),so I can use AUX option on player? I have cable under plastic on back side of central armrest(which AFAIK is for AUX):
I saw that on some outlanders,this connector is located under armrest, next to power outlet-that would be ideal solution for me(if cutting plastic is not big problem)
but if that can't be done, I would be satisfied with just cable like this
http://www.saunika.sk/img_prod/248850_V.jpg
P.S. I need just audio adapter,not video
I bought these splice connectors from my local auto parts store:
3M SCOTCHLOK Quick Splice Wire Connector - Blue Gel - 14-18 AWG (Qty 1) 3M Accessories and Parts 804C
I grabbed a pair of earphones, cut the cable, stripped the wires and soldered them to thicker (higher gauge) wire that would work with these splice connectors, and then connected right to that AUX cable you found.
Black is common, White is Left, and Blue with silver stripes was Right.
You could do the same with RCA Cables, just tie the commons of each channel together in some fashion.
