AUX input installation (again, I know)
Old Jan 9, 2014 | 03:34 PM
Ladisv6's Avatar
Default AUX input installation (again, I know)
Hi, I am new here. I have read probably every articles about installation the AUX for iphone. But I am still not sure if I 100% need the mit-pod adapter - so sorry for this new thread. I have the connector in the arm rest console - 5 wires. I just want to play music from my iphone via 3,5 jack, I don't need charge it. Is there a diference between using the adapter in arm rest and the connector C-15 in the back of factory radio? Or I need in both possibilities to buy mit-pod adapter?
Old Jan 9, 2014 | 03:47 PM
Vadimus's Avatar
You don't need an adapter. Stop throwing money out
Armrest connector is wired to radio or MMCS so it is the question of your convenience to chose either.
Old Jan 9, 2014 | 04:09 PM
Ladisv6's Avatar
what is please MMCS? I don't have navigation display, I have 6 CD changer only. I set up the radio tu AUX and I checked the connector in armrest and none of those 5 wires had a signal. And those wires don't have a "shielding" to transfer the sound. Can those wires transfer sound anyway?
Old Jan 9, 2014 | 06:25 PM
Vadimus's Avatar
I meant radio or MMCS (stock navi).
Why do you expect a signal on Aux which is input? It receives signal not sends it out
Old Jan 10, 2014 | 10:40 AM
Ladisv6's Avatar
yes, but I still expected some signal because of the connection with radio unit. Are on the back of radio any free pins, that I can use to new 3,5 jack cable? I can't come by those pins :-(
Old Jan 10, 2014 | 03:37 PM
Vadimus's Avatar
I suppose you'd better pass this challenging task to someone a bit more electric-savvy.
Old Jan 10, 2014 | 04:24 PM
Ladisv6's Avatar
yes, I will :-) thank you for help, I appreciate it
Old Jan 16, 2014 | 09:27 AM
quixmac's Avatar
Old Jan 17, 2014 | 09:57 AM
Ladisv6's Avatar
So I definitely need an adapter? What does this adapter do? Does it change signal?
Old Jan 18, 2014 | 08:51 AM
quixmac's Avatar
I dont know what adapter do, but I know without it I could not listen to ipod music in my car, and now I can. So you can spend $50 and start listening or keep doing research.
Ckmann
Jun 28, 2016 10:25 PM
BlueDev
Apr 2, 2007 09:47 PM
arius
Feb 22, 2006 09:47 PM
arius
arius
Feb 22, 2006 05:23 PM
