AUX Input - Totally stuck HELP PLEASE
Old 10-21-2008, 06:00 PM
Default RE: AUX Input - Totally stuck HELP PLEASE
you put in:
Code:
 [IMG] niftyurl.com/image.jpg [IMG]
Old 10-21-2008, 07:31 PM
ORIGINAL: mitsupartsman.com
How do you embed a pic onto a thread? my posts would look much better that way.
thanks in advance
I use the service tiny pic @ http://tinypic.com
then you just click on the "image" button at the top of your post window and in between the image tags you place the http link to the image from tiny pic.
Old 10-21-2008, 07:35 PM
Wow,I can't beleive they don't have a standard jack in the newer models.At least I've got mine when it come out and replaced that stupid radio with Alpine line.Maybe you should go into that direction if you want more !I have :minidisc,hdradio, 6dvd changer,ipod full speed control ,aux input for anything else.
Old 10-21-2008, 07:42 PM
ORIGINAL: cutienoua
I would love to have a built-in Mini-Disk in the Outlander, I have so many of them from when I was in Japan... right now I have an external Mini-Disk but it kind of sucks to have to charge it every week...
Old 10-22-2008, 04:15 AM
kenuck's Avatar
Well, I checked under the seat and indeed the harness is not installed. I have ordered it seeing that I am "electronically-challenged"[sm=laughat.gif]
Anyways, it should be here in 10 days and I'm sure that will solve the problem.
Thanks for your help folks!!
Old 10-22-2008, 06:44 AM
mitsupartsman.com's Avatar
Thanks for the tips.........lets see if I can post this parts bulletin.
SUCCESS!! [sm=smiley20.gif] forth times a charm
OK, this harness connects in place of the jumper connector in case you want a rearvideo screen.
Old 04-01-2013, 04:09 PM
Xapis's Avatar
Default Parts wanted
Hi where can i order this adapter for the the RCA Aux cable found at the back and bottom of my Outi 09 arm rest.
pablodavila4
10-11-2021 07:11 AM
mitsnewbie68
10-03-2012 09:52 AM
angel73
06-21-2011 12:17 PM
wolfie8
11-02-2009 11:14 AM
jshem746
32
11-06-2007 05:21 AM
Quick Reply: AUX Input - Totally stuck HELP PLEASE
