Aux and phone connection on MMCS
Old May 31, 2016 | 01:43 PM
gspritchard's Avatar
Default Aux and phone connection on MMCS
Hi,
Just collected an 07 Outlander 2.0Di-d for my partner. The "elegance" model, which seems to have the MMCS system and RF audio.
When we press the Mode button, the option for AUX appears, but I cannot find the ports to plug into anywhere.
I have run into the "secret menu" and the video connection is On.
I have pulled off the rear of the centre armrest and there is a plug connected to the plastic covering, C-117 I believe.
Secondly, how does the phone connection work on these? I'm going to guess it isn't Bluetooth... The buttons are on the wheel and when I click the icon under Navi it shows a signal icon and battery, but the audio system says no phone connected when I click the voice command.
Thanks in advance
Old May 31, 2016 | 02:46 PM
binzd's Avatar
for the BT, you have to pair the phone while in Park, assign it a priority, then you will actually be able to make calls, the 07 has to store the numbers and contact itself, it does not take contacts from your phone, good thing is since you record the name the unit will recognize names the way you pronounce them, but beware, that thing can be temperamental at times, requiring you to erase and re-add the phone, for me it's like every 6mo-12mo I add the same phone back
Old May 31, 2016 | 03:53 PM
Cheers, just figured that out. How strange to use voice commands to pair it. If only it would support music too.
mhc1990
Jan 30, 2021 12:00 PM
Doublecheese
40
Jul 27, 2020 07:57 AM
hutchoutlander
May 25, 2018 02:45 AM
LouisASX
Oct 28, 2012 01:10 AM
Paid2Much
4th Generation
Dec 13, 2005 07:25 PM
