Backup Camera
Old Nov 3, 2015 | 02:23 AM
SERPENTOR's Avatar
Arrow Backup Camera
Anyone get one installed if so which one and how much did it all cost you?
Old Nov 3, 2015 | 08:45 AM
Guyfromhe's Avatar
I got a $6 jobbie on eBay that is made to fit in the OEM hole. Works pretty well (Sony CCD sensor, virtual lane marker).. Install was pretty simple, I didn't even have to pull the plastic trim off, you can just slip it under and put a bead of clear silicon under it. You need to make a hole in the metal to run the wire through... Took me about an hour in the cold and dark.
I have an aftermarket system but you should be able to splice into the video pins if you have the OEM one.
I have seen the OEM cameras on eBay as well, they are like $300.
lastexile
Nov 20, 2012 12:58 PM
stealththx
Jul 11, 2011 10:46 PM
Kmart888
Mar 2, 2011 02:31 PM
jnetter
Apr 13, 2008 11:16 PM
sbessel
Apr 26, 2007 09:06 PM
